Thu Apr 22, 2010 9:54 am by Frankenstein
O.k, Let's try something drastic. Hot wire the coil, a new wire right from the battery plus terminal to the coil plus term. Then, if there's some way, give the distributor a direct ground to the battery neg terminal. Don't go through the fuse. Take the ride, use the lights see what happens.
The points in question are, wiring to-from battery, fuse, engine ground, and yes the distributor itself. I know, I know, all wires are new, but the idea is to find a combination where the bike WILL run, then work back to find the problem. Going the other way hasn't gotten the answer yet. Sound like a plan?
I'll try to find a pic on the web of what an indian distributor looks like, as I'm not familiar with Redskin equipment.
Dick
