More XLCH numbers...
epinut
Post Thu Dec 31, 2009 1:31 pm
Does anyone know how to interpret following numbers found on a -65 XLCH? First belly numbers, I'd guess the first says July -65 but what about the rest? The second pic is the neck casting, what do they mean?
Thanks Stefan.
Post Thu Dec 31, 2009 7:07 pm
Re: More XLCH numbers...
epinut wrote:Does anyone know how to interpret following numbers found on a -65 XLCH? First belly numbers, I'd guess the first says July -65 but what about the rest? The second pic is the neck casting, what do they mean?
Thanks Stefan.
That is not a date code. It is a model code. 7 was a Sportster. 65 is the year. It was the 3531th set of cases matched and linebored. Numbering started at 1000.
That is an Anti Theft number on the frame. You will also find one on the lower triple clamp.
epinut
Post Fri Jan 01, 2010 4:47 am
Thank you Chris!
epinut
Post Fri Jan 01, 2010 10:55 am
Btw, when did they start counting? Model year or calender year?
Post Fri Jan 01, 2010 11:36 am
Model year.
epinut
Post Sat Jan 02, 2010 8:36 am
Chris Haynes wrote:Model year.
Thanks again! Do you also know when the model year starts?
Post Sat Jan 02, 2010 10:41 am
Production changeover is usually during June/July. But new models don't hit the streets till August/September
epinut
Post Sun Jan 03, 2010 11:33 am
Once again, thank you very much Chris!
Return to Sporties
