Board index Flathead Power-Technical Questions, Answers, and Suggestions Sporties Rod set
Rod set
Post Sat Nov 21, 2009 12:48 am
Are the rod sets marked RPLS P245124-53 that I see allover eBay any good? Any one have any experience? I won't need any stronger than stock for this application but certainly don't want any weaker than stock.
Thanks
Post Tue Nov 24, 2009 9:00 pm
Aw come on somebody must know about these. At just under $135 a set they probably fall under " if it sounds to good to be true it probably is". But I would sure hate to buy something that costs double for no reason.
Post Wed Nov 25, 2009 8:54 am
Dusty, They come with aluminum bearing cages. Junk. Why not just buy a nice made in USA oem rodset with the earlier steel cages? I probably have some stashed away. PM me if I can help you out.
Post Fri Nov 27, 2009 10:56 pm
amklyde,
Did you get my post?
Post Sat Nov 28, 2009 9:58 am
Dave, Didn't get a message, I sent one your way.
Post Sun Nov 29, 2009 12:05 pm
Didn't get yours either!Even went through the junk folder. Try
clements@la-tierra.com
or
davidc@lanl.gov
Dave
Return to Sporties
