Side play of connecting rods between flywheels
sands
Post Wed Nov 11, 2009 10:55 am
Hi! The side play of (forked) rod between flywheels mentioned in the manuals is 0.006-0.010". What is your experience with these values or with larger side plays up to 0.04"? :roll: Thanks!
Post Wed Nov 11, 2009 11:38 am
Re: Side play of connecting rods between flywheels
fhsmith1
Post Thu Dec 10, 2009 4:54 pm
I got an assembled flywheel / rod set from Ted's that had over.090" between the forked rod and flywheel. Machinist had to make side washers for flywheels similar to what a shovelhead has.
X-WLCH
Post Thu Dec 10, 2009 6:43 pm
DID YOUR ASSEMBLED FLYWHEELS COME WITH THE CORRECT RODS ?
fhsmith1
Post Fri Dec 11, 2009 5:25 pm
X-WLCK
The first set came with OHV rods (too short). Bad thing is the whole bottom end was done, sealed up and ready, cams and all before I realized it. I put a piston on and turned the engine over and the piston hit the flywheel.
I was checking the second set a little better and saw the excess rod side clearance before I installed them. The second set also bound up slightly when turning the rods. Had to redo the rod inserts and rollors.
