HEAD LOCK
Tim 435
Post Fri Oct 23, 2009 8:29 pm
HEAD LOCK
Found a nos head lock w/keys but how do I get the old one out " 65 Pan " ? any help appreciated , thanks, Tim
37ULH
Post Sun Oct 25, 2009 10:01 pm
Re: HEAD LOCK
try a search Tim as this has come up and was thoroughly explained by Chris. The short of it is it's pinned in from my understanding with pinning hard to detect without blasting. Welding something to the pin to get it out.
Any chance that there might be another where this one came from as I need one for the 67 project?
Good luck.
Tim 435
Post Mon Oct 26, 2009 8:11 am
Re: HEAD LOCK
Hello Steve, yes what i've found it is pinned, problem is the frame is painted so welding is out, tried drilling the pin out with no luck, next will talk to a locksmith and see if he can make a key for the original in the frame, if that works I'll sell you mine for what I paid or you can try Bills Custom here in Pa., thank, Tim
Post Mon Oct 26, 2009 10:45 am
Re: HEAD LOCK
Too bad ya started messing with it before you found out how to do it. The way is to weld a small blob on top of the pin. Then use a pair if visegrips to pull it out. With the pin removed everything comes out easily. THERE IS NO OTHER WAY TO REMOVE IT WITHOUT DESTROYING IT..
37ULH
Post Mon Oct 26, 2009 11:18 am
Re: HEAD LOCK
Thanks Tim and good luck. Having the key made should not be a problem if the lock assy is there and not compromised. A good locksmith can just look into the tumbler, read it and cut the key correctly the first time most of the time.
Just looked at my 65 keys and the key blank should be b334.
Let me know 750uhv@gmail.com
Post Mon Oct 26, 2009 7:25 pm
Re: HEAD LOCK
37ULH wrote:Thanks Tim and good luck. Having the key made should not be a problem if the lock assy is there and not compromised. A good locksmith can just look into the tumbler, read it and cut the key correctly the first time most of the time.
B334 is the code number for your lock. Now that we all know it.......:D
