Board index Flathead Power-Technical Questions, Answers, and Suggestions Indians Stuck hollow axle
Stuck hollow axle
Post Thu Oct 22, 2009 7:41 am
My 640 front inner axle doesn't want to come out of hollow axle...it appears to be the same as manual diagram.
Any ideas beyond heat & beat? cotter pins are gone, it won't budge. I thought that rust may have piled up at the zirk locking it in.
This axle/hub/bike was outside against a barn for decades.
Post Thu Oct 22, 2009 10:12 am
Soak it in CRL [ calcium lime rust ] remover. Get it at all department and hardware store. Soak overnight, rinse thoroughly, clean black crap off of it and your hands, re soak in penetrating oil. Should tap right out then. NOTE: axle and sleeve will turn black. Pa
Post Mon Oct 26, 2009 12:07 pm
Thanks Pa.
Has anyone heard of racers replacing hollow axle set up with solid axle?
I thought I would throw that out before getting too involved...
