Board index Flathead Power-Technical Questions, Answers, and Suggestions K-Models KHK Cylinder Oiling
KHK Cylinder Oiling
Post Mon Sep 21, 2009 7:22 am
Hi George, wish I could help you, but I never pulled mine. Did as thorough a job as I could flushing things out short of removal. Not by the book, maybe, but those screws sure act like they're in there to stay.
Post Mon Sep 21, 2009 8:33 pm
Herr Dr,
That's why I asked here about getting them out.
I think that I will be able to clean the passages out enough. But would like to remove them just to make sure that there's no crud that will eventually come loose and clog up such a tiny hole.
George
Post Tue Sep 22, 2009 11:07 am
Hi George,
Inertia screwdriver should do the trick, the kind you hit with a hammer...
Post Tue Sep 22, 2009 6:24 pm
Does anyone have a set of tappets as pictured 2nd from the left with 3 holes for sale?
Can anyone identify the source as to OEM and what models or are they aftermarket?
TIA
Steve
Post Tue Sep 22, 2009 7:40 pm
Try this
http://www1.mscdirect.com/CGI/NNSRIT?PM ... O=71115729
If it were me I'd slide a solid slug inside the bore so the area is well supported.
44
Post Tue Sep 22, 2009 8:35 pm
Afraid of striking them, use an impact wrench instead of a driver.
Previous
