Board index Flathead Power-Technical Questions, Answers, and Suggestions Big Twin Flatties Id on Ul intake nipples
Post Wed Sep 09, 2009 4:02 am
What is the id on Ul intake nipples?
I have serched this forum and the net but cant find any information on it.
Post Wed Sep 09, 2009 9:13 am
GuS
33,1mm
1,303 inch
Dont think the one I have are OEM, but I don't remember.
GuS
Post Thu Sep 10, 2009 3:55 am
not bigger than that, thought that they where alot bigger than wl.
Do you know what size the ul manifold has?
Post Thu Sep 10, 2009 11:52 am
GuS
Sorry cant help you have no U Y-intake.
GuS
Post Thu Sep 10, 2009 5:31 pm
don User avatar
I got 1.337" I.D. on both short and long manifolds, a couple that have been polished, 1.375" all the way to 1.430".
My N.O.S. nipples tagged 1112-37 & 27039=37 are 1.309" I.D.
I would taper the I.D. of the nipples to match the I.D. of the manifold, For smooth transition,
A Maximum of .250" into nipple at manifold nut thread I.D..
The manifold nut thread is .335" deep/long with a relief of 1.430" O.D.,
Then you have the threads that enter the cylinder.
don
Post Sun Sep 13, 2009 5:58 am
okey, thanks for the info
Decided to take up the wl nipples to 32mm instead of the trouble with machining.
But as im going to use stroker plates under the cylinders i have to make a new intake manifold.
Does anybody know the outside diameter of the original intake, want to make one that i can use the original intake nuts with?
Post Thu Sep 17, 2009 2:11 pm
GuS
Found my notes for the last WL Y-intake I opened up:
Od: 36.1mm/1.421inch, this is the spigot cut for the PEEK seals
Throat 35.2mm/1.386inch. Have installed a 36 Mikuni VM on this bike.
Did braze to add to the thickness just for safety, although I never cut into it from the inside.
GuS
