Board index Flathead Power-Technical Questions, Answers, and Suggestions K-Models Splined shift arm - from what year?
Post Mon Sep 07, 2009 12:43 am
Hi everyone, can anyone please tell me from what year the shift arm changed from smooth to splined?
Thankyou!
Post Mon Sep 07, 2009 12:48 am
Hi, suicideshovel65,
54 KH is the start of the smooth one, so 52 and 53 for the splined one. They kept the slined one on the racers for some reason.
Post Mon Sep 07, 2009 12:55 am
Thanks Patrick! Did they revert back to the splined type for later sportster models?
Which have you found to be better in your experience?
Post Mon Sep 07, 2009 6:21 am
They reverted back to splines in 77 when they introduced the gerotor Sporty engine and the reengineered left hand gear change with alloy pedal.
Only problem with the unsplined one, you've got to tighten it real tight!!!
Post Mon Sep 07, 2009 10:20 am
125 and Hummers also used the splined shift lever.
