Sun Sep 06, 2009 6:08 am by Neil74
I had a 76 Sportster do the same thing, chased it around the carb an the ignition for weeks. I would be running fine an it would just quit running,no popping , spitting , nothing. As soon as I pulled over an kicked it it would re-start an go for another few minutes only to do the same thing. Last time out I re-started it 5 times, started easy an idled , pulled strong an smooth an just turned off like you hit the key. Pulled the plugs an they weren't wet, so back home an off with the heads. I looked real hard at the intake valves, figuring if it was an exhaust it would pop thru carb, which it didn't. All checked out good clearance, but there was a small spot on the intake stems that I redressed an decided to open the guide another loose .0015. The bike worked perfect after that an never stalled again.Another problem area on a castiron head is to have the valves just a little too tight, many Sportsters I've worked on the same problem, When started first time easy, rest of day even slightly warm hard starting an popping. Back off on valve adjustment an it will usually cure it. I'll admit to knowing very little about Harley flatheads, I've only worked on 6 in my life time, but been lucky enough to see many Indians , Sporty's, Troubleheads , Pan's an Knuck's. We allways seem to chase an easy problem longer than something obvious:)
Good luck Neil74
