Board index Flathead Power-Technical Questions, Answers, and Suggestions Sporties 58 Ironhead with S&S shorty
Post Mon Aug 10, 2009 2:27 pm
It starts great idles great but when I crack the throttle fast it will choke out the motor completely, if I roll the throttle slowly it sounds and runs good with no stumble. Checked for intake leaks, motor is rebuilt stock. Could this be incorrect jets?
Post Mon Aug 10, 2009 5:53 pm
If you put the bigger tank and original seat assembly back on it, i might help you!
Post Mon Aug 10, 2009 8:49 pm
If you can find me that stuff I'd gladly put it on!
This was a basket case and unfortunately not all the stock stuff was there
Post Tue Aug 11, 2009 5:04 pm
Have you checked the accel pump setting? It's adjustable. Turn it down till it doesn't do anything then open it up again just enough to get a decent squirt. Have you tried it with the air cleaner on? You probably never will get it so that it will take throttle if you snap it open too quickly, on the other hand you should be able to roll it on at a reasonable rate. Have you asked your local engine builder what he thinks?
Post Wed Aug 12, 2009 7:39 pm
Hey Lee, I'll ride it down one of these days and show you what it runs like..Thanks
Post Sun Aug 16, 2009 2:10 am
Transition problems...
Usually means throttle is too much closed at iddle. Try opening it a bit on the stop screw and reset your iddle scew. That should help. Also check none of your transition holes are blocked.
Return to Sporties
