Board index Flathead Power-Technical Questions, Answers, and Suggestions K-Models Example of bad numbers
Post Thu May 28, 2009 5:42 pm
http://tinyurl.com/l8e4lg
Also note that this is supposed to be a 1954, but the VIN is earlier than the 1st trap door case.
Post Fri May 29, 2009 9:22 pm
D indicates dealer replacement cases ?
Post Sat May 30, 2009 1:29 am
Yep, that number is smaller than my trapdoorless 54KHK...
Yes, the "D" indicates a set of post 57 KH cases that have been factory moded to recieve the Sportster trap door for sake of smaller inventory.
There was another D set of cases ealier on eBay, unground pad, factory numbers but no letters in it!!!
Post Sat May 30, 2009 7:30 am
Right... except for the grinding marks and over-stamp.
Never mind.
Post Sat May 30, 2009 11:31 am
I like the "test" "D" at the 3 o clock position of the timing plug hole.
Post Sun May 31, 2009 11:35 pm
Those pictured numbers aren't stock K and subsequent early ironhead numbers, which don't seem to have such pronounced serifs?
