Board index Flathead Power-Technical Questions, Answers, and Suggestions Indians Indian 640 frame info needed
Post Fri Apr 10, 2009 9:03 am
I brought a army scout roller home from Kentucky last week, it leaned against a barn for several decades so there are some weathering issues such as dissolved rims, etc. The biggest challenge I see is the rear-most section of the of the dash mount has been sawn off. I need dimensions for the flat football-shaped (as seen from above) piece. Specifically, length, width, distance between the two end holes, threads of same, etc. This would be easy enough to capture from frame kicking around garage, but I forget that many of you enjoy assembled and running bikes!
Any input (besides stop collecting abused relics) would be greatly appreciated.
Post Sun May 03, 2009 10:59 pm
See if these help, Photobucket cropped them at random.If you play with the size until an inch on the tape is an inch they may be of some use.
Post Mon May 04, 2009 6:31 am
Awesome Dave.
Mine is cut off flush with the rear part of the casting the frame tube enters.
I may be able to dump these photos into CAD and reverse engineer it.
Thanks
Jerry
Post Mon May 04, 2009 9:19 pm
Jerry,
If you need more views just holler. I'll probably take at least as long as this time to respond. Can't seem to get my act together except every so often.
Dave
Post Tue May 05, 2009 8:58 pm
Dude!
You need to post your pictures using http://www.photobucket.com
Post Wed May 06, 2009 9:29 pm
They are hosted at Photobucket.com. I wasn't very impressed but I got what I paid for.
