Board index Flathead Power-Technical Questions, Answers, and Suggestions K-Models Breather valves & oil pump gears?
Post Sun Mar 15, 2009 2:18 pm
I'm trying to figure out the differences over the years... Here's what I "belive to be right" so far...
52-55: Shorter shaft on the breather valve & thin gears, different body plate.
56-59: Same length on the shaft up to 76, as well as body plate, thicker gears.
And that's pretty much all info I've been able to dig up. Can anyone please fill in the blanks? Breather window sizes & gear thickness?
Thanks Stefan.
Post Sun Mar 15, 2009 3:14 pm
Did a little searching & found this:
viewtopic.php?f=19&t=7732
Post Mon Mar 16, 2009 4:11 pm
Ok, I'll try & narrowing it down a bit... Anyone that knows the difference between a 26331-56 & a 26331-60 breather valve?
