741 frame dimensions?
tprjj49707
Post Tue Nov 11, 2008 11:50 am
I recently acquired a 741 front frame that has neck issues; I am guessing this frame was a donor & gave up its neck for another project. Someone half-fast welded on a different neck (with slight 'rake') with bubble gum/seagull sh*t welds. I am going to remove the neck and evalaute what is salvageable.
My questions are, what is the measurement of the tope tube, from neck casting to seat casting?
Stated another way, how much tube is exposed between those two castings?
What is the length between castings on the tube that runs from lower neck to front of motor?
Thanks in advance. Also, which rears will bolt up to 741? does 640?
Post Tue Nov 11, 2008 5:01 pm
Re: 741 frame dimensions?
Any sport scout rear section will bolt on. One of the best riding 741s I ever rode had a 640 rear section and wheels.The 640 rear section has much more bracing and is very rigid. The racers liked the 741 rear section because it was lite but it doesn't handle as well as the heavier rear sections. I will walk down and get a top tube measurement in a little bit.
zooma
Post Tue Nov 11, 2008 7:49 pm
tprjj
Most of the frame measurments are in the 741 manual that you see for sale as a reprint but good information nontheless and very useful to build
your frame jig with or streighten or check your frame parts.
another reason that dirt track racers use the 741 rear frame is that it puts the axle lower so raises the primary cover for more ground clearance.
Also the use of the 741 fork is common as it is slightly longer than the 640.
good luck with your project.
zooma
Post Tue Nov 11, 2008 7:57 pm
tprjj49707,
No top tube measurement tonight the rubber between the tanks is so old and hard I can't get it out to see where the castings end. If no body has a bare frame I can pull the tanks this weekend. There is a print of a 640 front section in the archives at the Virtual Indian site. I have a bare 640 frame but I am not sure that the top tube is the same length.
tprjj49707
Post Tue Nov 11, 2008 8:43 pm
Thanks Dusty Dave. Don't pull the tanks just for a measurement...I saw 640 rear plans on VI, I am not a fabricator so I have to estimate time to build times hours labor plus materials.
I saw where you had 741 rear plans in the works on the LAST page of this forum from 1999...did
you ever get that project off the ground?
Post Wed Nov 12, 2008 12:18 am
tprjj49707,
Never did get the 741 rear drawn, just couldn't get a fame and a draftsman together. Lyle Landstrom runs the Blueprint Project now.
mineral94
Post Wed Nov 12, 2008 4:01 am
tprjj49707,
Where are you located? I have a scout frame fixture table and can repair your front section reasonable for you if you would like to discuss it, feel free to contact me at rocky@ironwigwam.com .
Rocky
1957S/VG
blackbob
Post Sat Jan 03, 2009 3:54 am
what is the measurement of the tope tube, from neck casting to seat casting? - 390mm
What is the length between castings on the tube that runs from lower neck to front of motor? - 300mm
taken from my spare 741 frame by trusty tape measure
are spare castings available ? ESPECIALLY THE HEADSTOCK CASTING
tprjj49707
Post Mon Jan 12, 2009 10:44 am
Thanks Blackbob....my only question is your last item...are you stating necks are available, or are you in a similar quandry
seeking one? I struck out finding one on my own. Anyone with leads on that OR a 741 right case half let me know.
blackbob
Post Mon Jan 12, 2009 2:20 pm
no, i was asking if the castings are available, my spare 741 frame has suffered at the hands of a chopper god :evil: when I got it it was raked to take a 10" over set of HD springers, it had heavy gussets welded either side of the neck casting, once removed - this is what I am left with
tprjj49707
Post Tue Jan 13, 2009 8:56 am
I will be glad when this 'old school chopper' fad has run its course.
Users browsing this forum: MSNbot Media and 1 guest
