Board index Flathead Power-Technical Questions, Answers, and Suggestions Pans 58-58 Tank emblem
58-58 Tank emblem
Post Tue Jul 29, 2008 12:18 am
Gents,
how are these emblems originally attached to the tanks. Mine are a bit wobbly and I would like to fix them
thanks
KLaus
Post Tue Jul 29, 2008 11:25 am
They had rivits that went thru speednuts on the backside.
Post Tue Jul 29, 2008 12:28 pm
The rivets, clips, and gaskets are available from Old Dude in GA.
VPH-D
Post Wed Jul 30, 2008 8:13 pm
Klaus.........
I sent you a PM did you receive it??
George
Post Thu Jul 31, 2008 12:40 am
George,
no. Not sure my adress is updated
Send to klaus.stingl@alcan.com
thanks
KLaus
Post Sun Sep 14, 2008 2:34 am
I have a 57 pan with the same problem.The plastic emblems are loose. I want to remove and reinsall emblems for paint.
Is there a special tool? I understand that it's a rivet but not sure how to work with them.
Post Mon Sep 15, 2008 2:00 pm
Use a punch with a concave tip to try to tighten the rivet by tapping lightly.
To remove the emblem, use a center punch to to locate the center of the rivet. Find a drill bit slightly smaller than the rivet head and drill it out. Go easy, you don't want to drill into the emblem. Once the head is gone, use a drill bit slightly smaller than the rivet shank, and drill it out.
Have the new rivets and clips on hand to gauge how far into the rivet to drill.
VPH-D
