Thu Jul 31, 2008 12:03 pm by Barry55KH
Hi Dave,
I was going through all your pictures of your Beautiful KHK, (I am jealous!) and found one when you mounted your generator and voltage regulator on Fri Mar 14, 2008 4:15 am . The wires look like they are set up a little funny to me. Did you rewire it before you started her up? I may have missed another post about it, but it looks like you have two wires running off the Generator's positive terminal, when there should be one. This one runs to the generator terminal, the center one, and is doubled up with the one from the generator warning light from the Head Light. The F or Field witch comes off the front post on the Genrator. I always turn the regulator around so the termanals are tward the outside, making it easy to get to the terminals. This way if I want to run a "Battery Tender" I can just clip it on the first terminal, or the Bat. The wire from this one goes back to the wiring plate, then to the right left side switch, and then to the right side switch, back to the plate and then to the horn, and back to the Pos. terminal on the battery. Makes it easy to charge the battery.
The wiring diagram in the owners manual is kind of confusing. I hope you got it set up correctly, or it can be big problems for the Voltage Regulator, Generator, etc... I have put my battery in backwards, like a “DoomKauf” before and it will run! It just wont charge. Turns it into an instant British electrical system. (Pun intended)
I find it easier to put the wires on the bottoms of the terminals, instead of the way the factory pictures show them as looping around from under the bottom of the regulator. The other way tends to wear the wires prematurely, and makes it hard to clip a battery charger onto.
Let me know if you have not started her up yet.
Best Regards,
Barry55KH
- Attachments
- KH Lives023.JPG (65.49 KiB) Viewed 2842 times
