Another non stock front brake
Post Sat Apr 19, 2008 7:05 am
Here's a link to a front brake setup I'm working on for my Flattie Chopper. The brake is mostly done, I posted over on John's site some info to help George, thought I might as well put the site up here as well. I've tested this caliper on my Bobber last Fall, it has at least the stopping power of the older '74 Sporty caliper I had been using. Mostly I liked the way this one tucks in behind the girder leg. Just satisfies my sense mechanical beauty.
Here's the link to more pics
http://www.freewebs.com/dicky_linn/chopperbrake.htm
thefrenchowl
Post Sat Apr 19, 2008 11:05 am
Re: Another non stock front brake
Hi Frankie,
Yes, a right mix of parts!!!
That's the beauty with H-Ds, anything can be made to work with whatever else!!!
If you were to want the caliper on the other side of the forks, the 74/76 one will be on the back as well...
Post Sat Apr 19, 2008 11:11 pm
do you find any particular effect on the handling, having the caliper behind the leg? I don't know much about these raked geometries and I would guess that the greater weight of the girder fork reduces the effect anyway, because of the relative weights of the components, but it would be interesting to know
milwaukee belle
Post Mon May 05, 2008 12:01 pm
...i don't think there are any differences with the front brake of a stock 883 sportsters ...
same place ( behind )
only one disc ...
and IMHO ; a girder's work is the same as a telescopic ...
Post Mon May 05, 2008 12:55 pm
no, the relative sprung and unsprung weights are very different and the travel and damping of the girder fork is much less than ( most ) telescopic forks. A girder fork will skid and patter under braking long before a telescopic with the same wheel and caliper set-up
I would guess that the girder is less affected by the placement of the caliper because it is a smaller percentage of the unsprung weight, and that having the caliper behind the leg tends to increase the self-centre ( castor ) effect; but the raked fork angle tends to increase this anyway so again, the effect is less than a telescopic and less than on a stock fork angle
but I've never tried it so i'd be interested to know
Post Mon May 05, 2008 3:14 pm
Well, it's been a long while since I rode an extended girder, and it had no real brake. So, I'm interested to see what this setup does also. My thought was that the frontend won't load under braking as much as stock rake/length, so it just might want to skid more easily. especially with a 3.00x21 on front. I've never bought into placement of the caliper having an effect on handling, to date. It always seemed to me that the force exerted on the fork leg was the same, whether the link pulled to exert it or pushed. However, you indicate it's the placement of the unsprung weight that has an effect. Elucidate please, I'm open to learning, even at this late stage of decrepitude. :lol:
Post Mon May 05, 2008 3:25 pm
well, I'm not 100% on the maths, ( meaning I have never troubled myself to find out ), but the principle is easily demonstrated.
block up the front end and take out the wheel. Now, turn the bars. With the caliper above the axis ( in front of the leg ), the weight of the caliper will tend to swing the leg to the stop. With the caliper behind the leg, it will act as a pendulum and tend to centre the fork again. The heavier the fork leg relative to the caliper, the less the effect is, obviously. Likewise, the shallower the fork angle, the less the effect; a vertical leg will not react one way or the other.
there are a whole range of variables, the weight of the fork assembly is one, the weight of the wheel assembly, the fork angle, you get the idea anyway. Triumph and Ducati did a lot of work on this in the 70s. Most 70s production bikes had the caliper in front of the fork because it's easier to assemble and service, but if you have a quick flick around in Google images you will see that behind the leg is now usual, and this is the reason, ie handling.
I've never much liked 3.00 x 21" wheels on Big Twins, I think they are inadequate in terms of tyre contact patch for the weight of the machine, so I expect you are right about the wheel tending to skid under braking
milwaukee belle
Post Tue May 06, 2008 12:21 am
Ouch !
too complicated for me ! :oops:
but Okay guys ! ....keep'on !
Post Tue May 06, 2008 1:11 am
's easy really .. if you stand a grandfather clock upside down, it stops working....
HonestJohn
Post Tue May 20, 2008 10:55 am
so, How does that effect the timing? :roll:
Post Tue May 20, 2008 3:44 pm
stops it dead.... isn't that what good brakes are for?
HonestJohn
Post Thu May 22, 2008 8:24 am
I always liked a 21 or a 16 Frontrunner for runnin in South Jersey sand. The larger diameter seems to make it easier to climb over the rut. On the road aluminum rims on a 18 or 19 are just fine. Honest
