Presidio High School Knucklehead Special
This year the Presidio High School Upper Level Metals & Mechanics Class, AKA SkillsUSA Chapter 2538, built a Knucklehead Special for competition in the Projects class at SkillsUSA, formerly VICA, competition. My first motorcycle was a 1946 Knucklehead 74” that I owned for 25 years; I sold it during a medical crises in 1992 and have regretted parting with it ever since. I teach the class and sponsored the project, buying all of the parts and materials used in completing it.
[img]
Two years ago we built a 1940 Flathead 80” Bobber that won a “Best of Show” trophy at the Texas SkillsUSA Championships. The bike belonged to me and I rode it around the Big Bend area for the next year. It was a great bike, but had some engine over-heating issues here in the desert that were due to inherent design flaws of the large displacement side-valve engine; it would not tolerate long-distance high-speed runs in the desert heat. Ultimately the front connecting rod blew at the big end with little warning, taking the crankcases and front cylinder along with it. I decided to sell the remains of the Flathead motor and look for a Knucklehead engine to install in the Bobber chassis; I located a basket-case Knuckle engine in Denton and picked it up last summer. The engine change required a new set of OHV Fatbob gas tanks to match as well, and I wanted to up-date the stock drum front brake to a disk to improve stopping. I started gathering all the needed parts and we set to work last August.
[img]
Although the basket-case 1947 engine was fairly complete, I wanted to up-date many of the critical components for maximum strength and reliability. The bike is a custom, and I was not concerned with keeping it totally original or doing a restoration; I wanted old-time style with modern reliability. I sold or traded many of the original engine parts to collector friends of mine and we assembled a Knucklehead Special.
The crankshaft and cases are the foundation of the engine and we went with new S&S Cycle Super Stock crankcases with a stroker flywheel and crank assembly from Truitt & Osborn, running forged-steel H-beam rods. This set up uses late-model tapered roller bearings on the crankshaft, much stronger than the original flat roller bearings. We used Michael Brown Solutions Knucklehead replacement cylinders which have thicker walls than standard, allowing for a 3 ½” bore and giving us, with the 4 ¼” stroke on the flywheels, a total engine displacement of 80 cubic inches. The cylinders and cast 8.5:1 compression ratio standard 80” Shovelhead pistons were sent to Boretech in Ohio, who bored the cylinders and applied their silicone-carbide embedding process to the cylinder walls, said to provide up to 3 times the life of bare cast iron cylinders. I also had them Teflon-coat the piston skirts as well as ceramic-coating the piston crowns. Many other up-dates and improvements, such as a centrifugal-advance ignition timer, late-model CV Keihin carburetor, Andrew’s cam, S&S billet aluminum oil pump, Primo Belt Drive with a late-style clutch, and 12 volt electrics, were included, giving us a vintage-looking engine with modern power and reliability.
The challenge to incorporating parts from so many different models and manufacturers was that all fit and clearances had to be carefully checked to make sure that everything would be compatible. We received much good advice from folks on this forum as well as from Al at S&S. I supervised the job closely, double-checking everything, but the students did all of the work, from 3-angle valve job to checking the run-out on the flywheels and assembling the cases. They adapted the star-hub wheel to run a disk brake, machining all the needed spacers, and did the paint job. I am very proud of the high quality work they did.
[img]
The style of the bike is that of a 1950’s era street racer. The look is deliberately rough-hewn and reminiscent of the racetrack. The guys who painted the scallops and hand-stripped the gas tanks of the original custom bikes and hotrods of the 1950’s had been painting similar designs on the engine nacelles of American fighters and bombers in Europe and the Pacific not too many years before.
[img]
[img]
[img]
The bike scored a Blue Ribbon at the SkillsUSA District 2 meet in Odessa in February, and advanced to the Texas State SkillsUSA Championships in Corpus Christi in April, where it scored a rating of “Superior”. I think it was by far the coolest project in the exhibit hall.
[img]
[img]
I was not willing to ride the bike on the street until after we had finished showing it, but after the State meet at the beginning of April we fired her up. Two priming kicks, switch on, and the engine started on the first kick! Unfortunately it was throwing clouds of black smoke out the tailpipe and rapidly fouled the plugs. When we had overhauled the H-D CV Keihin carburetor we had installed the richest jets in the kit, so we went back and leaned things out a little; restart, no change. After fiddling with the idle mixture needle a little and getting nowhere, we swapped the CV for a 38mm Bendix we had on hand for another project. The bike started and ran fine! I really wanted to run the CV because of its self-adjusting qualities in relation to altitude changes, which here in the Big Bend can vary from 1,800 feet above sea level to nearly 6,000 feet. I sat down with the H-D service manual and started checking the parts shown in the exploded drawing one by one. Imagine my surprise when I checked the passage for the low speed jet and found only a threaded hole! That would explain all the black smoke… I asked the student who had overhauled the carb about the jet, and he said that there hadn’t been any low speed jets in the overhaul kit and he hadn’t thought to check and see if there was one in the carb. The carb came from the take-off pile at Big Bend Cycle in Alpine and apparently had been robbed of its jet at some point. As it happened, the day we made this discovery, my wife, who also teaches at Presidio High School, was in Odessa for a workshop, so I got her to stop by the H-D dealership and pick us up a selection of jets. Next morning we screwed the richest of them into the carb, buttoned everything back up and varoom, she fired right up and settled into an even lope. The engine loads up a little at steady throttle and idle, puffing a little black smoke out the tailpipe, but I think I’m going to leave it a little rich until I’ve got 2,000 miles or so on the clock and am sure the rings are seated, then fine tune the CV a little
I’ve put just under 1,000 miles on the bike thus far, and it is running smooth and strong. We initially had an oil seep from the base of the rear exhaust valve tin, which has since sealed itself up; outside of that the motor has been oil-tight. The Teflon-coating on the piston skirts seems to be doing its job of reducing friction and keeping the cylinders cool. There has been no sign of any oil smoke from the top end out the tailpipe. We have had none of the problems that some other folks have experienced with the late model oil pump over-oiling the heads. As some of you may remember, we decided to set the pinion shaft bushing in the cam cover up for end oiling. Al, at S&S, advised me that it would be necessary to split the top end and crankshaft oil circuits as is done in the late model engines. This was easily accomplished by screwing an Allen screw, supplied with the S&S oil pump kit, into a pre-threaded passage in the crankcase behind the oil pump, and relocating the overhead oil line from the cam cover to the outlet supplied behind the rear lifter block on the S&S cases. I screwed a mini oil pressure gauge into the cam cover hole so I could keep an eye on the crankshaft oil pressure. Al suggested that it might be a good idea to restrict the overhead oil line to .060 at the crankcase fitting as well as where the “Y” line feeds into the rocker boxes, so I drilled three brass rivets .060 and inserted them between the line and the fittings at all three points. The rocker arms, fitted with plain bushings, seem to be getting plenty of oil and there have been no problems with leaks. The gauge on the cam cover, whose accuracy I am unsure of, shows 45 pounds of pressure when the engine is cold, rapidly dropping off to 10 pounds as the oil warms. I am running Mobil 1 V-Twin 20W-50W synthetic oil in an OEM horseshoe oil tank with a spin-on oil filter on the return line.
Altogether I am very pleased with the build and how the bike has performed to this point. I look forward to riding it long, far, and fast. I am especially proud of the high quality job that my Presidio High School students performed.
Thanks for your help and interest --- Randall Cater
