Sun Jan 13, 2008 7:55 pm by knucknutz
when i cut my pressure from 40 lb to 18lb heads quit gussin but bike smoked,so i kept cuttin pressure.s&s litature says that pump is suppose to put out 15-12 lb cold an 2-3 lb hot both at idle,i called s-s and talked to them for 45 mins ,no help,they couldnt tell me why pressure was so high.i ask them when they came up with this.060 hole in fitting in timing cover ,what pressure were you runnin? all i got was dead air(nothing).all he said was"some people plug fittings in heads to an drill.060 hole in them to". i ask him about goin smaller than .060 an he said dont do it.i ask him about these brass bushings with the groves in them, he said put the stock ones back in an see if that stops it,like it was like workin on a freakin evo or something,i dont think he ever worked on a knuck.these pumps where made to feed hyd lifters & PUMP 1-2 ozs of oil per min. to primary chain ,an this oil now needs to be bipassed, the reson for cutting spring,and also why pressure is so high.i ran this s-s pump on a motor for 5600 miles till pinion bearings failed,which i think was do to junk bearing cages(guess where i got them) and i didnt have any problems at all with heads,no pluged an drilled to .060 fittings,an was runnin 38-32 lbs of pressure all the time but i was runnin stock rocker arms that had .0025-.0035 wear so i went with new ones ,wanted fhp ones but they would never call back,so i got v_twin ones,which had .0025 clearance rigth out of box,h-d says .0005-.0015,so i didnt gain much,thats why i think its those brass bushing with those groves IMO
