Modified K Engine Part 2
Tim The Grim
Post Mon Nov 26, 2007 8:07 pm
Here are some more photos. I started a new topic so the pictures wouldn't take too long to load in the 1st one.
A couple more of the cases and oil tube set up.
2 of the " T " bracket that fits between the cases and mounts to the frame on that part in the 2nd frame pic.
And finally my sprocket cover / clutch actuator that I machined using an idea from an old Arlenn Ness product that he
made for Sportsters in the early 80s but interfered with the rear exhaust on a KHK.
As Porky Pig would say... "That's all folks"
Patrick, That's a real nice concept you have there and great artwork too. Thanks for your thoughts.
Tim
'54 KHK since 8/70
'76 XLCH since 4/85
'97 Valkyrie since 10/96
Tim The Grim
Post Mon Dec 03, 2007 10:24 pm
Re: Modified K Engine Part 2
Here are the pictures of my KR cams of unknown letter designation. I think they are "A" grind.
The other ones with the color on the gears are my Wire EDM cut lobes that I designed using Autocad and cam timing specs from the KR KRTT book. I ground most of the bad lobes off but left a "Key" for reference and then silver soldered my lobes on to the OEM gears.
My lobes are D-2 tool steel and have the same lift at .395 but have a little less radical profile than the real KR grind.
To reference an other post...When I had a set of KHK cams, which had not come with my 54 KHK when I bought it,
they were marked KHK on the 2 intake cams.
I had the shop that 1st built my motor for me put them in so I have no idea of their origin date.
Tim
'54 KHK since 8/70
'76 XLCH since 4/85
suicideshovel65
Post Tue Dec 04, 2007 2:48 am
Nice!
