Board index Flathead Power-Technical Questions, Answers, and Suggestions Shovels "O" Ring Chain
"O" Ring Chain
Post Sun Jan 28, 2007 12:19 pm
Howdy,
Any recomendations for good quality "O" Ring chain for my 76 FLH? Pay a bunch for a couch, hell no, pay a bunch for scooter stuff, You bet!!
Thanks Rigidscoot
Post Sun Jan 28, 2007 11:27 pm
The best O-ring chain for a Harley has straight links, the eight-form links are for faster(less heavy) bikes imo.
Stéph
Post Mon Jan 29, 2007 1:15 am
I used to run o-ring chains on both my rigid pan and swing arm pan shovel. I lubed them periodically with spray chain lube and they never gave any problems.
However, each time I took the chains off due to wheel lube, tire and brake inspection work the chain was so stiff like, hard to bend. Granted I think they are a stronger chain but their an overkill for a typical 4 speed big twin, you know they gotta be robbing some power and drinking the gas.
In the old days everybody would go and buy a Diamond chain for something like 20 bucks, big motors too. Only once did I see a buddy break a chain, it was neglected and old.
Too tight a chain on a swing arm will not only wear too quickly but it also will beat out the high gear and eat up sprockets. Rigids are a little easier to understand.
Tsubaki makes a good "mid range" "stand style" chain, can't remember what I paid for the one I put on my rigid pan recently but I think it was about 60 bucks. Diamond would still be a good choice if their still around.
The place for those high dollar stainless o-ring chains are those stupid fat tired choppers, those skinny little belts work only because they aren't ridden much.
Just my opinion.
-little hoss
Post Mon Jan 29, 2007 5:37 am
Diamond rear chains are JUNK,JUNK,JUNK!!!!
Post Wed Jan 31, 2007 7:03 pm
I never had a problem with a Diamond chain.
Post Thu Feb 08, 2007 11:57 pm
I use RK chains.
Mark.
Post Fri Feb 09, 2007 3:31 pm
RK or Tusbaki, IMHO. G
Post Fri Feb 09, 2007 4:39 pm
Tsubaki has the best price for the value.
Curt!
Return to Shovels
