Identify the cylinder contest
Jerry Wieland
Post Sun Jan 28, 2007 6:59 pm
Here is a link to a cylinder. I would like to hear from our experts on what vintage they think it is and whatever else that they may know. Hopefully the answer will surprise a few people.
Follow the link and look under Knuckle cylinder.
http://new.photos.yahoo.com/hd36ohv Thanks Jerry
amklyde
Post Sun Jan 28, 2007 8:23 pm
Looks like a rear cylinder from a 36 knuck. What am I missing?
Post Sun Jan 28, 2007 8:29 pm
It appears to be a 4 fin 1936-1939 61" OHV cylinder.
Jerry Wieland
Post Sun Jan 28, 2007 10:34 pm
I am going to let this go for a few days and see what happens. Kyle, you know the answer if you just think about because you and I have talked about it.
Jerry
Post Mon Jan 29, 2007 8:48 am
Perhaps if we had more than one dark photo we could make out what it is. It does carry the part number of a 1936-1939 61" OHV cylinder.
Jerry Wieland
Post Thu Feb 01, 2007 8:04 pm
Chris I apologize for my poor photos but I am a tractor/motorcycle mechanic and not a photographer.
OK - more about the cylinder. If you are an astute knucklehead kinda guy and see this photo you will come to the same conclusion that Chris came to - 4 fins = 36 to 39. If you even more knowledgeable you will recognize this as a 1936/37 cylinder by the raised casting numbers. Somewhere around the 1937/38 split they changed the casting numbers to recessed - I have never been able to determine when.
Now - would anybody believe that this cylinder was actually made much later than that - 1944 to be exact - June of 1944. If you do not believe me go back to original post and follow the link now and see the second shot of this cylinder with its' 6-4 casting date. This is the original rear cylinder on my 1944 E knucklehead. My 1943 E has the same rear cylinder only with a 10-2 casting date. Ronnie Cox's 44 E has the same situation.
Here is the only explanation that I can come up with. All 3 of these bikes have a late 39 casting date on the front cylinder so I surmise that they must have had a bunch of fronts in warehouse and made a rear to match but somehow used the earliest casting mold that they had.
I would love to hear anything anybody has to say about this.
Jerry
Eric @ B.O.S
Post Tue Feb 06, 2007 11:29 am
Jerry,
Nice info thanks for sharing.
About the recessed / raised casting numbers on cylinders, I have seen an untouched 38 EL export bike in the 3000 serial number range that still had the raised numbers. Hope this helps.
Eric
Eric @ B.O.S
www.beautyofspeed.com
amklyde
Post Tue Feb 06, 2007 12:54 pm
I took a look at a pair of cylinders I have for my 38, with raised part #'s and the casting dates are 12-31 and 10-7. Did they use a week-day system?
Post Wed Feb 07, 2007 11:11 am
I have looked at a few dozen Knuck cylinders in the past few days. It appears the later 5 fin cylinders have a full date code on them. A raised letter fot the month and the tag with the day and year on it. All of the 4 fin cylinders I found had a code system I haven't figured out yet. Things like 41 9. Anybody have a clue to this earlier date code system?
Return to Motorcycle Trivia
