Zoom, when you change the oil look for "color" in the metal flakes that will cling to the bottom of the external oil filter cannister. Bronze flakes are okay. Grey metal, we don't want to see much of.
I use a paper towel to wipe the cannister inside and put it in a baggie. The oil gets sucked up by the towel over time and leaves just the metal for you to pick through and wonder at. Or, (used to be) you could pour the content-dregs of the external oil cannister, into a sample bottle for spectrographic anaylsis, and have the concentration of metal particles expressed in parts per million at JIMS. Part # 2399. Have your shop call them about it if you're interested. You use alot of gas and oil for the first 600-900 miles. Check the level everytime before you ride it. I change oil at 100, 500, (1,000 maybe) and 2,500 miles thereafter. You'll see metal particles diminish with each change-out (unless you installed a dirty oil tank).
Or, just ride the machine until it quits. Either way, you're going to draw a huge crowd everywhere you go.
CAUTION: You can get someone killed out there. I've had people walk into traffic several times (once a dad dragging his son was almost run over by an incoming auto, between the pump aisle at a Chevron station). Another time a motorist almost rear-ended another car at traffic signals trying to look at my '59 instead of paying attention. And thats with a '59 too.... not a '36. The danger sign is when men get that glazed-over look in there eyes and start baby-walking towards it with their hands out-stretched. They've lost their minds at this point... and you have to shout at them to "Snap! dude"
Don't let it happen to you. You don't want to go through life with that memory, when all you wanted to do is exercise the OHV.
Thanks for the color combo's Chris. Somebody can use them in the future.
If you're bold enough to build a kit, you have the best "kitters" in the world right here. We've been there, like the Lewis & Clark of repop. We can collectively steer you through any problems you encounter, just don't go off on your own and try to "fix" something yourself, and then come on-site to complain because you made it worse. Ask for some directions first.
Why would anybody use double faced tape to put mounting strips on a bare tank? Silver soider works fine and holds the emblen close to the tank as it should be.- Haynes
Been there - tried that. "Cotten" led me into to that "use a soldering iron method". Sounds good doesn't it? I ordered the American Beauty industrial soldering iron and found that not only was it a pain to find a location for the mount strip in a "sea" of possible open area on the tank to choose from, but once you removed the adhesive strip from the mount plate, the mount screws for the emblem would need three divots put into the tank so the screws could seat. And, no advise was offered for that seemingly little task. Think about it. You could end up moving the alignment of the shut-off/reserve holes, by pounding three relief holes for the screws. And, the adhesive strips, mount plate and emblems go over a painted tank, not bare metal. Instructions for '51-54 placement are in Vol. 2, but you can figure it out on your own, by looking at the year-model pix in Palmers book.
Here's an OEM '51-53 tank. You can't get the same mounting strip by "soldering" on the aftermarket mount strip. You can see the dimples for mount screw relief. A lot of factory work went into getting emblems on the tank.
If anybody's going to make an application or mechanical suggestion here.....you better be able to back your suggestion up with the start-to-finish methods or you're wasting our time.
The adhesive strip takes up the protrusion space of the mount screws, as shipped. It was "Gin", during that period, that suggested going with Harley's emblem kit, as shipped. He was right. The adhesive strip is gas-proof too. Luckily, I was able to return the soldering iron, and found out in the process, that American Beauty now makes a 110V variable speed control, for building a 32E generator output tester, like Bruce Palmer suggested in his Big Twin Restoration book.
