Mon Sep 11, 2006 6:20 am by enigmas
Thanks Dick, I'll keep the needle spec in mind. Steph, I was going to paint the whole engine black and keep the aluminium highlights on the case fins, but thought it may be too black overall. The silver paint is rated for use on disc brake calipers and rotors, standing temperatures up to 900 degrees F /490 degrees C, with use it should dull down somewhat and stay intact on the iron heads.
47knuck it seems to work on other (45) magnum engines and certainly did on Crazy Eddie's, (still featured on Panic's "Victory" site) which from all accounts was very reliable. This engine should be stronger internally than Eddie's, as it runs WR rods and the big stepped crankpin. It also runs the mild XL cams as I'm more interested in durability than outright performance.
