Sun Apr 30, 2006 1:59 pm by BREWSKI
Got a chance to play with the toys today,for the unintiated Triumph people;the 750 sprocket shaft and the XL sprocket shaft are very close;spline wise as the clutch hub. Almost to where you could press the sprocket assembly on the shaft.,making a XL belt drive almost a bolt on.Which is where I got started on this electric starter setup,between mounting a Triumph alternator on the XL sprocket shaft,and machining a BILLET ALUMINUM oil pump body(ala XR750),this is the reason the KR/WL is still apart. Decided to mount a aluminum plate off the trans mount(as 'DOG and I stated)vertically;one piece .375" or thicker. It would be easy to machine with a SAWALL,jig saw,holesaw,etc.,picture framing the plate to fit around the trans case,providing a base to mount the starter assembly,running the plate tall enough to mount the starter housing. THIS IS ALL STRICTLY CONJECTURE AT THIS POINT,THIS IS STILL UNDER DEVELOPMENT. BREWSKI
