EVO flywheels
BREWSKI
Post Wed Mar 29, 2006 2:34 pm
EVO flywheels
Has anyone given any thought to using a XL evo bottom end in a WL? Some machining would be required on the sprocket (or cases)and pinion shafts,but the advantage would be the 3-piece bottom end and the shorter rods(as in strokers) BREWSKI
Post Thu Mar 30, 2006 8:06 am
This gives even more problems than XL wheels, since the pinion shaft is even larger, drive not compatible with the 45 pump etc.
BREWSKI
Post Thu Mar 30, 2006 12:27 pm
PANIC,you're right,the pinion shaft has to be machined to fit even the earlier XL's. I knew someone that put a put a ironhead XL bottom end in a WL,he machined the sprocket shaft to fit the WL bearings,I didn't agree with that;it would have been better to machine the cases for the TIMKENS. BREWSKI
Return to Evo's Thru 99
