resleeving ULH cylinder
VFDBill
Post Wed Mar 15, 2006 5:10 pm
I have a badly damaged UL cylinder with a sleeve already in it. How best to remove this sleeve for repair?
Jerry Wieland
Post Wed Mar 15, 2006 5:31 pm
I have never done this on a motorcycle sleeve but in dry sleeve tractors it works great. We weld vertically up and down on the sleeve until it drops out. The weld shrinks the sleeve.
Jerry
woody
Post Wed Mar 15, 2006 8:41 pm
The welding works, and you can also bore the sleeve out until it is very thin, and then it will just peel out.
100incscoot
Post Wed Mar 15, 2006 9:53 pm
i actually have always used the bore out till then idea
never thought of jerry's idea
i think if i was to try that i'd heat the cyl b4 welding it cause welds expand b4 they contract and under expansion it may want to crack the cyl
bikerblinky
Post Tue Mar 21, 2006 1:11 pm
The weld idea will probably work fine, I use a similer technique to remove valve seats. Running around the top of the seat with a tig torch untel the seat pops out. 8) I agree, pre-heating is probably a good idea, especially on that old iron.
gin
Post Tue Mar 21, 2006 5:00 pm
Another trick is you warm the cylinder then pack the sleeve with dry ice or use a Co2 fire extinguisher to cool the sleeve, it usually will drop right out.
Users browsing this forum: Bing [Bot] and 3 guests
