Mon Jul 18, 2005 1:55 am by ULFlathead
There is a BIG difference between the real original Flathead/Knucklehead frames and the Panhead frames.......espeically in their construction!
1-Flathead/Knucklehead frames were cold brazed at the factory, and they used spacing plugs intermittently in the frame to add flexibility and spring-likie strength to them. Try brazing or welding on one of these old frames without knowing what you're doing can mess things up for the frame and yourself down the road. [My advice is to let someone like Randy Simpson at Milwaukee Iron (Lynchburg,Virginia) restore or modify the frame to your likes.]
2- The original Panhead frames were tig/mig welded together. They need the 3/8" spacer for under the front motor mounts when putting a Flathead or Knucklehead mill in. These Panhead frames do not have the same flex and spring-like properties the old Flathead/Knucklehead frames had.
3- If you want to modify a Knucklehead/Flathead style frame, you also have the option of picking up one of the new reproduction items and hacking away without the worry of the old brazing and tube integrity.
Good luck and have fun!
