U-UL case
knucklehead61
Post Sun Jun 26, 2005 6:37 pm
U-UL case
Hey guys,I'm still in search of a set of good U-UL cases.
A few of you emailed me back but I lost your email address...sorry.I'm kind of computer iliterate.
I have a question about the 88 stroker fly wheels.Are they ok to use in the stock cases?and what type of pistons would I use.
If I build an engine with 88 stroker wheels,larger valves,carb,cams and flow work.What can I expect for HP..ball park figure.I do want a streetable engine,is this possible.Thanks for the help guys
Graham
Post Sun Jun 26, 2005 10:24 pm
KH61, the flywheels in a U type engine have a smaller diameter than a F type, brain's not working or I'd give you the dimentions.
Graham
100incscoot
Post Mon Jun 27, 2005 1:02 am
machine the od of the wheels down and your set
S&S probly makes a set or would turn them down for ya
m/cgeezer1945
Post Wed Jun 29, 2005 3:24 pm
S&S 4 5/8 stroker wheels are the right diameter for U cases. It has been my experience that you don't need to go that big with U series motors to go plenty qwik and fast. Bigger is not always better. Stock stroke makes torque numbers like a Shovel motor on the dyno. I would concentrate on cams,carburation,exhaust, ignition and gearing. Just my 2 cents. Big motors require more maintainence and more money. Cubic inches=big dollars. If you gots the money and the time, they are way more fun than most people need. Just be prepared to spend the money and the time. Geezer
Users browsing this forum: 1948u and 0 guests
