k or kr cyl???????
100incscoot
Post Wed Jun 15, 2005 7:01 pm
k or kr cyl???????
ok you guys are better at identifying k parts
is this a kr or k cyl ????
100incscoot
Post Wed Jun 15, 2005 11:39 pm
whats the # for kr?
the seat angle could have been changed later too
100incscoot
Post Thu Jun 16, 2005 5:01 am
you da man panic
i know i can always count on a short precise answer from you
these are not kr as they have no r on the #
thanx man
Barry55KH
Post Thu Jun 16, 2005 2:11 pm
Looks like an oversized valve to me, as I compare it to mine that is apart. I have those silly V-twin valves with the dip in the top. Anyone know how these will affect a street motor? I am hard on equipment, but don't do a lot of top speed work. I have a set of KHK cams I would like to put in at some point after I have them rebuilt, and will likely hunt up another set of valves for them then. These came in Sifton packages from V-twin. They ran OK on the last go around, though the engines lower end was so loose it eat through the rings very quickly, and the carbon messed up the pistons badly.
100inch, what is the base number anyway?
Best Regards,
Barry55KH
greybeard52
Post Thu Jun 16, 2005 10:59 pm
Mike, if the base # is -52, they're K, -54 KH. If it's K model, looks like some one put KH intake valves in it and dressed up the relief a bit. Is the intake passage cleaned up and smoothed also? G
100incscoot
Post Fri Jun 17, 2005 1:51 am
YEP THEIR -52 SMOOTH INTAKE PORTS AND HUGE VALVES
THANX ALL FOR YOUR HELP
Users browsing this forum: Yahoo [Bot] and 3 guests
