Mon May 30, 2005 2:25 am by JIm
Thanks guys. Got 125 miles on it so far, the weather took a dump today so the day was cut short. So far no big problems just a couple of minor leaks that needed fixing. I was a bit concerned that the valve springs I found and used might not work out but so far so good. Only time will tell.
I was looking for some info I had here on the valve springs that I found for the motor. I found some of it but can't find all of it. I wanted to post the info a while back but missplaced it. I am hopping they work out OK. The are real close to the ID and OD of the UL spring but shorter. Adjusting the lifters is easy seeing as how the covers will lift pass them. I got them through a local automotive machine shop. Below is the info that I have been able to find in my mess, (I suck at record keeping).
Here's what I have.
Free Length 1.860
Wire diam. .155
Coils 6
Solid Height .900
Height Pressure Pressure at 375 lift
1.440 - 80# - 170#
1.425 - 85# - 175#
1.410 - 90# - 185#
1.375 - 95# - 190#
1.350 - 100# - 200#
I had to make a large stool to make up the difference in length. I also made up some aluminum retainers for them.
Jim
[This message has been edited by JIm (edited 30 May 2005).]
