Board index Flathead Power-Technical Questions, Answers, and Suggestions Big Twin Flatties It's Finally Done
It's Finally Done
Post Sun May 29, 2005 2:19 am
JIm
What I have been calling the Flat Boy for a while is done. It took a bit over 3 years due to a bunch of different reasons but here it is.
Jim
Post Sun May 29, 2005 2:50 am
Excellent job Jim!! I've been wondering how your project was coming along. You personalized your build very uniquely. Pa
Post Sun May 29, 2005 3:01 am
A veeery big effort Jim. Nice work. How about some on road riding feedback when you have some time.
Congrats.... Vince
Post Sun May 29, 2005 3:54 am
JIm
Thanks guys. Got it running on Friday night. Took it out today and put 63 miles on it just to see how it was and do an oil change. Had one problem on the road. The terminal on the wire from the battery to the main breaker broke off. First road side fix. The bike handles great. With everything being new I am taking it a bit easy with it for a while. The 5 speed gearing pulls good although I haven't gotten it into 5th yet. Keeping the revs and MPH down for a while. With the gearing I have on it, it should go down the highway real good. If the weather hold up should get a few miles on it this weekend.
Jim
Post Sun May 29, 2005 3:57 am
JIm
Anyone that wants to see a bit more info on the build? Follow the link below.
Jim
Click to go to the Flat Boy Web Site.
Flat Boy
Why buy it when you can make it
Post Sun May 29, 2005 6:05 am
Jim-
That was indeed a Big job. Turned out Great!
Looks like you've got the best of both era's
Always like checking out the 'details' on your site, too.
Post Mon May 30, 2005 12:37 am
Very nice, Jim. I have also been wondering how the Flatboy was coming along. You have done an excellent job.
Post Mon May 30, 2005 2:25 am
JIm
Thanks guys. Got 125 miles on it so far, the weather took a dump today so the day was cut short. So far no big problems just a couple of minor leaks that needed fixing. I was a bit concerned that the valve springs I found and used might not work out but so far so good. Only time will tell.
I was looking for some info I had here on the valve springs that I found for the motor. I found some of it but can't find all of it. I wanted to post the info a while back but missplaced it. I am hopping they work out OK. The are real close to the ID and OD of the UL spring but shorter. Adjusting the lifters is easy seeing as how the covers will lift pass them. I got them through a local automotive machine shop. Below is the info that I have been able to find in my mess, (I suck at record keeping).
Here's what I have.
Free Length 1.860
Wire diam. .155
Coils 6
Solid Height .900
Height Pressure Pressure at 375 lift
1.440 - 80# - 170#
1.425 - 85# - 175#
1.410 - 90# - 185#
1.375 - 95# - 190#
1.350 - 100# - 200#
I had to make a large stool to make up the difference in length. I also made up some aluminum retainers for them.
Jim
[This message has been edited by JIm (edited 30 May 2005).]
Post Mon May 30, 2005 11:15 am
Nicest Softail I've ever seen!!!
Post Mon May 30, 2005 3:28 pm
Looks great Jim, glad she is testing out OK. I don't blame you for using that seat, I like a little back support also. The problem I see is trying to figgure out which carb to slap on. So many choices so little time.
Post Mon May 30, 2005 4:47 pm
nice work,that should keep the rubs scrathing their heads.
Post Mon May 30, 2005 8:38 pm
JIm
DC
No offence taken. Just using what I had around the basement. Probably will try a thinner one at some point.
ULHer
Right now I am using the DC 12 Linkert which is working OK. Probably going to stay with it for a while.
Thanks Indianut
greg1
You are right about the rubs scratching their heads and that even goes for people that have been doing it for a while. Was at one of the local dealers Saturday. Had a crowed around it. I had mentioned to one guy that I was told buy a few people that I could not do the 5 speed electric start. His reply was sure you can so I asked him how did I do it? His reply was uh uh, if you uh uh well maybe uh uh.
My reply was exactly.
Jim
Post Mon May 30, 2005 9:19 pm
JIm
DC
Stop reading my mind!
Just kidding
The plan is to probably change the front wheel to a 16 with a full fender or possibly a Fatboy fender next year. Haven't seen a Fatboy fender on a springer yet. Someone probably has done it though. I used to run 21" front wheels a long time ago until I hit a cobble stone on the interstate at 80 MPH. Can you say instant blow out. It was a bitch to keep the bike up but I managed to get to the side of the road and stop. Since then I have allways used 16" front but it was not in the budget for this build. If I use a full front fender, I will more than likely use a repop of an original springer fender and adapt it to the front end. Not a big deal. I don't like the looks of the new style front fender.
Got your number.
Jim
Flat Boy
Post Mon May 30, 2005 9:24 pm
Jim- certainly a "double-look" softail Image
DC-
I like your outlook about others critiquing
your ideas & machines..
Admittedly,I need to apply some of that into my thick head(glad U posted that)Thanks man!
Billy
Post Mon May 30, 2005 10:23 pm
I wouldn't change a thing except loose the bitch pad and go! I think the stock seat is fine the extra pad is the heavy one. I remember this project when it was a set of grenaded cases. You are to be commended and worshiped! I am not worthy! http://img246.echo.cx/my.php?image=flatboy7wj.png
http://www.fatdogvintagesalvage.com/
[This message has been edited by Fatdog Vintage Salvage (edited 30 May 2005).]
Post Tue May 31, 2005 12:00 am
JIm,
Like Fat Dog, I've been following your odessey since you first linked images to this site. We share the combination of new & old. I desired an electric leg for my chosen motor ( Knucklehaed ) over ten years ago. The build was a long drawn out affair. It is very difficult to tastefully blend the new with the old and still have a practical and aesthetically pleasing combination. Mention was made of combining a 16 inch wheel with the softail springer. You said that you thought that you might combine the two along with a Fatboy fender. I did so with Terrapin. Image In retrospect I would admit that It "aint right ". Had I been a little more critical, the angle of the mount would have been more complimentary to the lines of the springer and the frame. Enough about me ! Great effort JIm. JKE
Smoke 'em till the wheels fall off!
Post Tue May 31, 2005 1:17 am
JIm
Well thats the wrong login. It must be mental pause. This isn't the music site. I guess I'll have to post pictures of the guitars I make next.
Jim
[This message has been edited by JIm (edited 31 May 2005).]
Post Tue May 31, 2005 2:52 am
Great job, Jim. You are an expert craftsman.
Larry
