Board index Flathead Power-Technical Questions, Answers, and Suggestions 45 Flatties 65A Generators
65A Generators
Post Wed Feb 12, 2003 10:08 pm
Is it possible to use a 65A generator with the threaded end on side valve models?
Can the threaded end be shortened in order to fit in the cam case oil separator recess?
Post Thu Feb 13, 2003 3:44 am
It doesn't fit??
You may need to shim it to specs (as per the Palmer book), but I regularly slip a slinger onto 65a armatures for something to turn them upon my growler.
