Idea of cost to rebuild cylinders
scphantm
Post Tue Mar 20, 2007 2:38 pm
i have a set of 80 inch, 13 fin ULH cylinders that are already punched 80 over. for some reason i don't quite understand yet (im thinking bent rod myself) i had the oil ring come apart on the front cylinder and it destroyed the wall.
how much would you charge to take the cylinders, sleeve them, hard coat them, fit a new set of pistons, fit the rings, relieve the chamber for some better flow, valves, valve guides, valve seats, and new valve springs (heaver than stock i hope). keep in mind that on the front cylinder there is a 1/4 inch hole drilled into the skirt for a failed oil injector that would have to be welded before you can sleeve it. also i intend on having KNS regrind the cams for me, thus the desire to have the chamber reshaped a bit.
i don't intend on putting the injector back on it so it can stay closed. instead i intend on having the baffles welded back into the cases
thanks
willie
Post Tue Mar 20, 2007 6:44 pm
flatheadrider
Post Tue Jan 08, 2013 3:18 pm
Re: Idea of cost to rebuild cylinders
hey Pa ! your url post goes nowhere .
Not Found
The requested URL /US/FlatHeadPowerFrameSet.htm was not found on this server.
Post Tue Jan 08, 2013 3:42 pm
The link used to work. Try using this form. http://www.sscycle.com/contact/
Limey_Dave
Post Tue Feb 05, 2013 6:48 pm
The OP was from 2007.
I think these days the answer would come back as "fit these"
http://www.sscycle.com/feature/featureview.php?s_id=55
Return to Services Sought
