Board index Flathead Power-Technical Questions, Answers, and Suggestions 45 Flatties Handling problems
Handling problems
Post Mon Nov 22, 1999 4:38 pm
i think i remember something about the front neck rake being less than pan frames and this added to some satblity problems, also about the springers doing a little hopping when into sharp cornering. just a thought!
Post Mon Nov 22, 1999 9:35 pm
Linz-- It sounds like your rear wheel is not
lind up with your front wheel, not ajusted
straight,
benwa
Post Sat Dec 11, 1999 3:21 am
Do you have your spring thru bolts bridged? I was looking through Uncle Franks manual last night and there is a comment in there about the old HD's and excelsiors having stability problems and adding a bridge across the bolts??? Beats the hell out of me!
