Sun Dec 16, 2007 3:08 pm by d.rinner-okc
I was glad to see enigma's post. This is not 45" related, but hp & torque just the same. In 1975-76 I had a '74 XLCH Sporty
all stock except 38MM Mikuni & either 1-7/8" or 2" drag pipes. WFO it was great, but in town/traffic stumbled & farted alot. I was working at a H-D dealer, and one of the "old school" wrenches said he could fix it without spending any money.
We pulled the pipes, and about 6"-8" in, drilled a 3/8" hole on the inside (frame) side. He took 2) 3/8" x 1" bolts & slotted
both the hex-head, and threaded end (paralleled), then took ( I believe cam washers, or tranny shims) that had the OD of the pipe ID, and brazed them in the slotted heads. He fished them up the pipes and thru the holes, and nutted them. We
started test runs with the "washer" straight inline with the pipes, each run we would turn the bolt a few degrees, ending
somewhere around 30 degrees off straight thru. It made the whole package rideable, very little power loss @ WFO or (what I thought was important then) noise. The pipes did blue near the washers, but "Blue-Away" helped.
I've told this story to modern racers that kinda squint one eye & think "sure ya did"
OH, and when we had found the best adjustment, we center punched the pipe in line with the slot, when something changed, the washer alignment was the first & easiest thing to check!
d.rinner-okc
old harley parts are MY 401K!
