Board index Flathead Power-Technical Questions, Answers, and Suggestions 45 Flatties Recomend-chain or belt primary on 38ul
Post Wed Oct 06, 1999 8:58 pm
Belt be's best. I have always run Primo and have only broken one - a 2nd hand piece of shit that given to me. Just resist the temptation to run it too tight.
I run open primarys. Enclosed should be vented.
luck,
filthy
Post Sun Oct 10, 1999 7:15 pm
By all means, put a hose on the vent tube and route it away. I did this even on the rat bike. These old oil pumps/ breathers tend to puke.
filthy
[This message has been edited by filthy (edited 10 October 1999).]
Post Mon Oct 11, 1999 8:14 pm
Thanx alot fellas for the advice. Im gonna run the primo instead of the chain. Ive been ridin 45s and this is my first big flatty so ill definitly be hangin round here while im buildin this chopper for tips. thanx agian
matt
Post Wed Oct 20, 1999 12:50 pm
Hi again, Matt.
One, last thing: Be sure you get the pullys lined up exactly. Not hard to do and will extend belt life.
filthy
Post Thu Oct 28, 1999 7:52 pm
Thanx for the info lintz,question though. You guys think runnin a 3in belt is overduein it or should i go with the 1-1/2 belt. The tree inch looks tough!Is there any difference as far as performance/durability between the two?
Post Thu Oct 28, 1999 8:52 pm
Just an opinion but the 3 inch one is probabily overkill unless your really building some horsepower in this motor.
In this case less is more, but thats just my opinion, Being an opinionated putz, you wont have to build the guard around it so big
