dist. base
buddha
Post Fri Oct 29, 2004 9:03 pm
dist. base
I am in the process of finally installing my single point dist. I realized i have the base without the notch, which is the wrong style. Can I notch this out to fit the adjusting stud or is this completely out of the question?? I went threw alot to get this timer set up ( another time & another day to explain). Or should I locate proper notched base? thanx, Buddha
greybeard52
Post Fri Oct 29, 2004 9:27 pm
Bhudda, give us details; i guess this is a flatty, but is it a stock manual advance, auto-advance, Mallory, Home-bilt or ? distributor. G
buddha
Post Sat Oct 30, 2004 1:31 am
Sorry, it's a 45", G model, single points ('48 & up style), manual advance. If thismod. can be done, please give me the specs for the "notch". Is there any difference at all (other than notch) between these 2 dist. bases? Thanx, Buddha
sleeper
Post Sat Oct 30, 2004 6:07 am
Buddha-
'If you mean?' You have either OEM Part #32580-64 Base [circuit breaker] '64 & '65.
Or later '66+ up, these are auto-advance with totally different internals. Even the base is fastened down differently. The auto-a's have 2 studs come up thru the base cap, whereas Part #32579-49 "HAS THE NOTCH" you describe, but is held down by a retainer clip. W/very different timer shaft housing.
Even if you get the notch dimensions, you would have to place it very correctly & remove the advance weights, & etc..
IMHO, you would NOT get the satisfactory results, anyway.
If that's what you mean???
If you have the Correct "Timer Shaft Housing" I'd just get the right base.
[This message has been edited by BillyW (edited 30 October 2004).]
buddha
Post Sat Oct 30, 2004 12:53 pm
I have (2) timer bases #32506-37 (w/out notch). I realize this is wrong one for it does not allow for the adjusting screw head to fit when I try to assemble unit together. The bases I have are oem. Question is can I "notch" housing to accept adj. screw? If so, what would be the specs (ie., length,height)? This is for manual advance set-up. Palmers book (pg. 390) shows the 2 45" s/v bases, both look identical, except notch. Am I going the wrong route here trying to make this mod or what? thanx again, Buddha
redchief344
Post Sat Oct 30, 2004 1:30 pm
Buddha...unless originality is a concern, why not just use the timing strap and pre 48 points set? That would eliminate the hassle of trying to notch your base and screwing up an original part. Or...you can find 48 and up bases all over the place both NOS and used.
Post Sat Oct 30, 2004 3:09 pm
Budda, I agree with René, go ahead and notch it. It isn't rocket science and doesn't need to be exact. Just eyeball it from the pics you have and get it close. It's adjustable via the post and gear position as you drop the ass'y into the timing cover. You haven't really ruined an original piece as it can still be used at a later date with the original type timer head. Just my .02 of course. Dick
