mikuni main jet
Flatrat Richard
Post Thu Oct 07, 1999 5:16 am
I would sugest that you check for in take leaks Get the motor up to operation temp them set your ldle down to where she will just barley stay running take a can of carb cleaner and spray around your manifold if leak is bag motor will stall if only slight you will get a real rank smell out of exuast.
Post Thu Oct 07, 1999 11:48 am
What are the other jets?
filthy
Post Sun Oct 10, 1999 11:32 pm
'Nother trick: Do the same as previously stated, but spray it with either ether or The Miracle Juice - WD-40. If there is a leak, the mill will rev.
If this is not the problem, raise the needle.
And if that fails, get a smaller needle before going to another jet..
Hope this helps,
filthy
Post Mon Oct 11, 1999 3:02 am
Again - what pilot jet, slide cutaway, needle jet, needle, needle notch? All of these affect mixture, not just the main.
Users browsing this forum: Bing [Bot], Google [Bot] and 2 guests
