No Lead Gas?
Gruntis
Post Tue Dec 17, 2002 11:51 pm
No Lead Gas?
We got to put up with no lead gas over here,there is a couple of alternates.
we can find some gas stations that sell premium 95 but still no lead content,
What Are you guy,s Runnning in your stocker 45s Is there a Lead additive or are you just happy to go Lead Free
Should I be Tunning this sucker any Different,Maybe its me but I find Peformance
of this ol Heap changes from what gas stations I use ? WTF""
Thanks Gruntis
Gruntis
Post Wed Dec 18, 2002 2:57 am
Thanks Mate" Yep I took that as Gospel and gave them valves plenty of clearence on the rebuild.
Made stainless valves for this one,its only got about 300 miles on it now. Hopefully lots more over xmas.
I kinda reckon the cylinder head Temp Changes with fuel blends on offer as well,
Thanks Gruntis
Post Wed Dec 18, 2002 3:11 am
Lead was a bad idea in the first place. (But we shall ignore the health concerns for now..)
It's value as a stem lubricant is highly over-rated in light of chrome or nitrided coatings, and it's digestive effect on oil makes that a bad tradeoff.
The basic benefits of tetraethyl lead were two things: octane increase, which is a fart in the dark on a flatty, and insulation against spot-welding of the valve to the seat. That IS a concern, particularly if you run a stainless valve against a castiron seat.
So the ironic delemma that we are left with is that modern manufacturers of valves put out even nitrided units with a stainless core. Duh.
This means that they expect everyone to have hardened (not matrix) seats.
It's a no win situation at that point. Unless you have the wallet to arbitrarily replace your flattie's valve seats with hardened ones that can easily shrink at the slightest sign of an intake leak, advanced timing from points cam wear, etcetera..
This whole scenario leaves us with either the choice of going back to the most primitive of materials, (because it works!), or spending incredible amounts of cubic dollars on the latest fad of hightech coatings.
So in our despair,... we turn to snake oils.
moonWR69
Post Wed Dec 18, 2002 4:00 am
i've been racing flathaeads for 15 years and i have boxes of exhaust valves that have been trashed. the soution i've found is cast iron guides run loose and marvel mystery oil in the fuel. i've tried all different kinds of fuel (leaded and unleaded) and all octanes. call it snake oil if you like, but it works.
moon
Post Wed Dec 18, 2002 4:22 am
What lights the fuse every time is.... heat.
Find out where that comes from, and suddenly you CAN run stock spec on exhaust guides and straight fuel.
(PS: I DO use MM oil... on air filters.)
Gruntis
Post Wed Dec 18, 2002 6:52 am
WoW" Now thats a Tech Reply" Thanks Cotton & Moon
F... This sites Good"
Iam sold on the snake Oil ""
Now just Got too Find a Peddler
Gruntis
Eric @ B.O.S
Post Wed Dec 18, 2002 12:12 pm
Does anyone know where one can find Marvel Mystery Oil [or an equivalent] in europe?
Thanks,
Eric
Eric :: Knk45
www.beautyofspeed.com
A state of the art power quest
George Greer
Post Wed Dec 18, 2002 1:07 pm
Hi Eric,
Where you exactly? I am near Wurzburg, Germany. I can get you a bottle of MMO.
I have a bottle that I plan to use on my "rebuild"..
George
METALMAN
Post Wed Dec 18, 2002 4:24 pm
I buy Marvel Mystery Oil by the Gallon + use it in all my old + new Iron.Been usin it for many years as a fuel + oil additive
Eric @ B.O.S
Post Wed Dec 18, 2002 4:41 pm
I'm in France. How much are the bottles in terms on content & price? Thanks for offering!
Eric
Eric :: Knk45
gadget37
Post Wed Dec 18, 2002 9:36 pm
I've been running the titamium nitrated stainless steel valves cast iron (loose) guideswith the hardened seats and have never had a problem with them coming loose but I think that has a lot to do with who did the machine work. I have had him do several sets and have never had a problem. And of course I swear by the mmo snake oil.But keep in mind it doesn't take much. I got one of those harley octane booster bottles after it was empty and carry it on my bike so I can get an accurate measurement.
LIVE HARD...RIDE HARD
DIE FREE
GADGET
Post Thu Dec 19, 2002 2:03 am
The concern with hardened seats goes beyond the machinist's skills.
Most (not all) hardened alloys have the habit of shrinking when they reach a critical temperature. That is why you can remove them by welding a bead around their face, and then they easily fall out. The same thing occurs if you run lean or advanced.
It's a problem for OHV's to keep them in if something elevates the combustion temperatures. Flattys operate normally at a higher temp than OHV's so the fuse is that much easier to light.
No additive in a bottle can help this circumstance. And if you must start off with loose-as-a-goose clearances to get by in the first place,...then you better start pressuretesting your manifolds and degree wheel your ignition.
don
Post Thu Dec 19, 2002 3:52 am
For those who have not seen these posts,
As Amklyde has referred to "Drilled tappet blocks"; http://www.flatheadpower.com/ubb/Forum2/HTML/000120.html http://victorylibrary.com/wwwboard/messages//397.html
don
Post Thu Dec 19, 2002 5:05 am
Conan!
Now consider this:
Perhaps the MMO is just slowing the oil from crusting up from the heat. Modern oils aren't made for aircooled flatties. The additives burn into hard soot.
There will never be enough flow of lube to cool a flattie's valve stems.
Nitrided stems and soft cast iron theory assumes next to no flow. Modern OHV's even have seals to prevent flow, lest carbonization fills the gap, resulting in sticking and wear.
MM Oil is the one lube that carbonizes the least. But you cannot run pure MMO!
Conventional oils with modern additives will carbonize and stick a properly fitted valve at flatty temperatures.
(Inspite of what Shell says, Aeroshell is probably the best motor oil for such an application, as it is ashless.)
And no doubt moderate use of MMO can only help.(You know when you have added too much when your plugs foul out!)
I have no qualms about using MMO as a safety net, but it is just that, and only that.
It is not a cure for the causes of elevated combustion temperatures. Only common sense does that.
gadget37
Post Thu Dec 19, 2002 6:51 am
True fact and when I said loose valve guides I was not refering to "loose as a goose" just the loose side of the specs. Err to the side of richness and know what your engine is doing by sound and that takes and ear of experience I also failed to mention that I am running a thermostatic oil cooler. I definately recomend the cooler and thermostatic is the only way to go. And definately make sure of your intake seal as Cotton just might mention.(not to play it down as it is damned important!)
DIE FREE
GADGET
harrison
Post Thu Dec 19, 2002 8:39 am
Gruntis
try REDEX from Repco (maybe Aussie MMO)easy on the revs, compression & temps, (old stock wla's will run on kero!)our American friends gave(lend lease) us the gift of these fine machines 60 years ago, they have survived war, neglect and bush mechanics! A little bit of care & common sense & they'll survive "unleaded" crap gas too!
later
harrison
later
harrison
