Transmission mainshaft end play
I have new mainshaft, new thrust washers, new bearings..have measured the thrust washers and they are all correct sizes..
Went step by step by Palmer's book, compaired the army TM's also..but when I assemble the tranny to measure the end-play..the entire thing is locked up tighter than a frog's butt, (and that's waterproof).
Is there anybody that might have the measurments on the main-shaft, clutch gear?
OR is there a difference in clutch gears between model years..ie...two bolt vs. three bolt mounted xmsn's??
Getting frustrated with it..
Thanks all...George
