Board index Flathead Power-Technical Questions, Answers, and Suggestions 45 Flatties clutch hub stud removal
Post Tue Jul 15, 2014 3:37 pm
Hey guys I cant find any info anywhere on how to replace the worn clutch hub studs on my 45 ? Any thoughts ? they looked peened in place.
Leo
Post Wed Jul 16, 2014 12:02 am
I've never done this on a 45 but its a common job on designs from that period. Usually they are threaded into the basket and peened on the outside of the basket.
Post Wed Jul 16, 2014 6:38 am
45 clutch hub studs are lightly pressed and peened.
2478-41A stud
2477-41A stud
Post Wed Jul 16, 2014 12:02 pm
Wow, is that all? Are they an interference fit then? Do you chill the stud and warm the hub first?
Post Wed Jul 16, 2014 12:21 pm
Interference fit is correct. Just press them in at room temperature but protect the end of the non threaded stud with brass and protect the threaded stud with a nut. Heat the peened end after pressing to soften the steel for peening. I use a jewelers torch to do that task because the tip is mini and the flame hits only the peening area.
Post Wed Jul 16, 2014 4:19 pm
Thanks a bunch, I appreciate the info.
Leo
Post Thu Jul 17, 2014 4:38 pm
One more question on the clutch hub studs. How should I take the old ones out ? Grind off the peen ? Hand file the entire surface hitting all the studs ? It seems like it could be a big mess.
Post Thu Jul 17, 2014 8:36 pm
Use a die grinder on the peens being careful not to dig into the hub itself. You only need to take the peen off real close to the hub surface. The thin excessive material you leave behind will fold up like foil and follow the old studs out while pressing them out. Use a press pilot just a bit smaller than the area of the new studs press shank. A 1/16" smaller diameter pilot is sufficient. Just make sure you press it straight and use support beneath the hub on the side the stud pushes out from.
Post Fri Jul 18, 2014 5:44 am
I'm aiming to rebuild the clutch for that 45 project with the Shovelhead forks while I'm home, so THIS thread needs to be on my bookmarks list..
Post Fri Jul 18, 2014 10:44 am
Hey thanks again PA, I thought that was the way but wanted to check with you, the expert !!
Post Sun Jul 20, 2014 6:13 pm
Expert .....LOL .......It is trial and error Bro ! I've done the worse and found out the best.... LOL
