Board index Flathead Power-Technical Questions, Answers, and Suggestions 45 Flatties DNA Springer
DNA Springer
Post Sat Aug 10, 2013 7:20 am
Hey folks has anyone used a DNA springer on their 45 ? The prices are very inviting, I do know you would use a BT axle, brakes and neck cups.
Post Sun Aug 11, 2013 8:13 pm
I've put them on a couple of BTSV's I've built. They have a universal 3/4" axle, put whatever brake you want to adapt to it. Comes with an anchor mounting threaded hole on each rear leg. I've adapted late 70's era calipers to them. the stem is 1", might need some adaptation to make that fit the 45.
The springers themselves actually ride pretty good for not having any dampening.
Post Mon Aug 12, 2013 7:57 am
Thank you very much for the info, I think I will go ahead and use one.
