Oil pressure issue?
37ULH
Post Tue Apr 23, 2013 3:39 pm
Re: Oil pressure issue?
I would guess that levers or a hammer would work well. Some may accomplish this with only a wrench.
Post Tue Apr 23, 2013 4:05 pm
37ULH wrote:I don't see how cam bushings could cause wet sumping, sorry!
Because The oil flow enters the pump at the rotor and vane area before it stops at a check valve ball. It is here where the oil leaks past the bushing into the case. Click on the actual pic to view a larger size. Use your back button to return to topic.
44dwarf
Post Tue Apr 23, 2013 4:49 pm
I'd bet the fine gents up at Harbor Vintage in Jones VT could set you up with a good pump at a reasonable price.
Never been in the door but i drove by the place for 2 years while in school....keep meaning to stop in when i'm back up in that area but allway pressed for time.
37ULH
Post Tue Apr 23, 2013 4:54 pm
Thanks for the diagram as i hadn't really looked at it in detail, not having had issue in past that couldn't be easily resolved by substitution. The supply, including my own, is dwindling. I have three left not in use that all need repair so this is helpful.
Post Tue Apr 23, 2013 11:52 pm
The factory got it right as long as the tolerances were to specs between the cam journal and gear cover bushing. To loose and oil gets past the additional clearance.
X-WLCH
Post Wed Apr 24, 2013 8:09 am
SOME PEOPLE HAVE SUCCESSFULLY RE LAPPED THE BALL SEAT. ( I THINK IT HAS BEEN A TOPIC OF DISCUSSION SEVERAL TIMES ) AND A NEW SPRING MAY HELP.
IT'S WORTH A TRY BEFORE REPLACING THE PUMP, AND CHECK THE BUSHING.
I FIND THAT THE BEST SOLUTION IS TO NOT LET THE BIKE SIT FOR A WEEK WITHOUT RIDING IT. :wink:
Post Thu Apr 25, 2013 4:20 pm
The gear cover pump bushing flange can have an effect on oil leakage around the cam journal as well.
bluesman
Post Mon Apr 29, 2013 9:17 am
New Balls and springs and no sumping after one day and excellent pressure. I drained out the crankcase and got the correct 3 or so oz. out, so now to wait a week and see if it all drains out or stays where it should in the tank. Not sure I can refrain from riding her that long!? :mrgreen:
bluesman
Post Wed Aug 14, 2013 9:06 am
Well, I guess I spoke too soon, because the last pump was working, but sumping I replaced it. This replacement pump provides great pressure but sumps just as bad or worse than the previous one. It will drain a quart every 2-3 days into the case. The return flow at the tank is strong, and I did drain the case after riding and it showed the proper 3 oz. of oil in the bottom, so the system seems to be working well with the exception of the pesky sumping issue.
The second pump I used was an original harley pump that showed very little wear. It is of the newer? style with only 2 springs/balls. It was media blasted and I installed new springs and check balls. The darn thing looks almost new!
Pa, you said " The gear cover pump bushing flange can have an effect on oil leakage around the cam journal as well." How do I inspect for this, is it simply looking for play at the pump flange bushing with the pup removed?
I am not sure what else to do next other than the controversial lapping of the seats. I am going to pull the pump, clean it and put it under a high powered scope to inspect the ball valve seats. I am not sure of any way to "bench" test the pumps ability to not leak past the balls. :?:
wilko
Post Wed Aug 14, 2013 7:36 pm
Just put up with it like thousands of others.
Previous
Users browsing this forum: Bing [Bot], Google [Bot], Majestic-12 [Bot] and 6 guests
