Mon Dec 10, 2012 2:47 pm by arc1953
Well.....I'm presently waiting for a reply from Belt Drives Ltd. concerning a replacement clutch pulley. This morning I did some more measuring and studying. Flipped the belt over and bent it and saw little hairline cracks between the teeth. Needs replaced. That belt was new in '84. Closely examined the clutch pulley. Yes, it would be possible to machine it and fit a new pulley rim to the old. Although the front pulley is good enough to go for a while, it does show a little wear. I am starting to think that it may be wiser to replace the whole thing. In 1980 when I bought the Phase 3 unit, I think it was a little under $400. I see that Flatlands has one for $485. It would be possible to buy a new belt and acquire a pulley repair section and have it machined and spend nearly that much. I will wait to see the reply from BDL, but I am starting to think that it would be smarter to just replace the whole thing. If the new one lasts as long as the old one, I will be 90 and probably not care if it slips a little. Maybe I'm getting smarter. Thanks for the thoughts and input........ARC
