Board index Flathead Power-Technical Questions, Answers, and Suggestions 45 Flatties 65a generator ce-540 regulator
Post Mon Aug 06, 2012 6:41 pm
does anybody have a wiring diagram for a 45 with a 65a gen with the cycle electric ce-540 regulator.i bought the bike as a basket case and after two years starting to assemble it.the only problem im having is figuring out how to wire the gen light in the dash.the rest is pretty basic.but this is my first time with this type regulator.
thanks steve
Post Sat Aug 11, 2012 8:42 pm
Try connecting the wire from the gen light to the "A" terminal on the generator. This will give the gen light a ground when the genny is not outputting. When the output goes higher than Battery voltage, the light goes out.
Post Sun Aug 12, 2012 5:08 pm
thanks for the reply stein.thats the way i always wired them in the past,but this is my first experence with a solidstate regulator.just needed a second opnion.
thanks steve
