Board index Flathead Power-Technical Questions, Answers, and Suggestions 45 Flatties Wo's running a Brit Trans?
Post Sat Nov 09, 2013 6:27 am
I did do a sketch showing a bush welded to the frame, supporting a lever bent at 90 deg, and a shoulder to retain it at the left-hand end. The right-hand end was to be milled square to mount the crank and then threaded for a retaining nut.There was a bush slid over the exposed, right-side end and retained by the crank to provide lateral restraint from that end.
But I just decided it was too much work for no advantage and didn't do it.
Post Sat Nov 09, 2013 2:01 pm
What did you decide to do instead ?
Post Sat Nov 09, 2013 7:40 pm
Initially, a short rod to the original gear pedal to give a right-side foot change and a long rod to a Servicar clutch pedal to give a left-side foot brake ( BSA rear wheel ), handlebar clutch lever
But I've recently acquired a stock Ariel brake pedal and since the bike has the original mount for that I'm converting it to mid pegs using that on the left and a stock Burman fear pedal on the right, so there are no linkages at all
Previous
