piston weight wl
hi does anyone have access to a unused genuine standard size wl pston please ,mid 40's . as i would like to compare the weight differance with the k model pistons im going to use and if alot different , modify the pistons to get the weight the same. the engine bottom end is together and good so i dont want to split it to rebalance the crank. regards jib
