Date of birth
JON
Post Thu Nov 10, 2011 1:06 pm
Date of birth
Hi everybody,
JON
Limey_Dave
Post Mon Nov 14, 2011 12:14 pm
Re: Date of birth
If your WLA is early 1943 it will have engine number 42WLA**** and case (belly) numbers 42-335.
JON
Post Mon Nov 14, 2011 1:44 pm
Re: Date of birth
I Looked it again and correct belly no. is 43-*335. By Palmer´s book (How...military...) my bike´s engine no. refers to type III and that engine-number range ends at april 1943 (page 69). I also understood from his book that this belly no. is for case that was machined and stamped 1943 and ready for assembly (page 9).
Check Your pm.
JON
Post Mon Nov 14, 2011 10:43 pm
Re: Date of birth
There should be date codes cast into the cases.
JON
Post Tue Nov 15, 2011 12:18 am
Re: Date of birth
JON
Post Wed Nov 16, 2011 11:05 am
Re: Date of birth
JON
Look on the outside of your left case behind the primary cover. You will find a letter and a number on a small raised boss. A= January, B= February, ETC. 1= 1941, 2= 1942, ETC. This is the month and year your case was cast. It was built into a motorcycle shortly after.
JON
Post Wed Nov 16, 2011 12:17 pm
Re: Date of birth
Thanks!
